Need advice on best card for my budget.
12 Feb 2009
London
Hi I'm currently have a 260-216 that is pretty old now so looking to get a new card.
It has to be nvidia as the game I play runs so much smoother on nv.
My budget is £150-200 and I'm happy to buy a used card.
My rig is a 2500k @ 4.3
16GB ddr3
750w corsair ax.
Dell u2410 1920/1200
Thanks in advance.
It's a pity your game is so much smoother on nvidia as this card in b-grade is so much more powerful than anything you will get on the nvidia side.
http://www.overclockers.co.uk/showproduct.php?prodid=BG-022-HS&groupid=595&catid=683
If its nvidia you want then a gtx660 is all you can get on here in your budget.
Second hand maybe you could pick up a gtx670 if your lucky.
What game is it you are playing.
What's the difference between b-grade and normal? Are the b-grades less likely to OC well, or something?
I just signed up to say thank you for this deal its on its way to me now lol.
Was going to buy this card new anyway.
Bump up the budget and get a second hand 670 Brad. Will be worth it to run at that res with dynamic lights on.
