- 30 Nov 2010
- UK
Hi,
Just wanted to make a quick thread for my build.
The original build was done from a Ocuk bundle I got back at the end of 2011, since then I have been changing things as I go
3770K @ 4.8 using 1.215v
Asus Sabertooth Z77
8Gb Samsung Green overclocked to 2133Mhz
Crucial M4 128GB
Crucial M4 128GB
WD 1TB Black
LG BD-RW
Corsair 650D (dremel front)
200mm Bitfenix Pro Spectre
Corsair AX850
Evga 680 2GB
Evga 680 backplate
Lamptron FC5 V2 fan controller
2x Akasa Vegas LED strips
1x Corsair SP120 performance with Demci filter (rear intake)
Dell U2711 2560x1440
Watercooling:
Alphacool XT45 240mm radiator
Phobya 200mm V2 radiaror
XSPC Raystorm cpu block
EK-FC680 GTX Block
150ml Bitspower reservoir
8x Bitspower shiny silver compression fittings 7/16 5/8
2x Bitspower 90 degree rotary fittings
1x Bitspower T connector (used for drain port)
XSPC 90 and 45 angeled fittings
2x EK nickel 7/16 5/8 compression fittings
Stop caps are mix between BP, XSPC and EK
XSPC fillport
3x XSPC male to male connectors
XSPC D5 pump
EK CSQ pump top
Primochill Advanced clear tubing 7/16 - 5/8
Mayhems UV Blood Red
2x Synthe Gentle Typhoon 1850 fans
Current (June 2013):
Pic's of how I had the system before:
Asus Sabertooth Z77
Crucial M4 128GB
Crucial M4 128GB
WD 1TB Black
LG BD-RW
Corsair AX850
Evga 680 2GB
Evga 680 backplate
Watercooling:
EK-FC680 GTX Block
XSPC fillport
XSPC D5 pump
EK CSQ pump top
