NEED HELP: Hardware security
17 Jun 2009
Swansea
We've recently installed a few PC's in a youth center and the kids have been pulling all the leads out at the back. They are unable to be staffed 24/7.
Without boxing the PC up doesn't one know of a way i can put some form of security back plate on to counter this?
YOU cannot do that with out putting it in a cabinet where there is a wire it can always be be pulled and if you use wireless chance are they would get lost or walked off with.
All you can do is monitor them or remove them only security your really get for computers in public area are the anti theft ones or sofware bases which would not help you.
Build a box or something and just put it in there with some holes for ventilation and staple the wire down on the inside off the box so it's unable to be tugged out of place?
