CAPS
18 Oct 2011
When you have uninstalled the CAP files the folder and its contents remain in the AMD folder, if i delete the folder after the uninstall this is ok right?
AMD have an answer for all these sort of questions right here :)
Use that next time, for now just delete the folder.
Edit..'again' CAP's yes, i'm stupid.
AMD don't do that anymore, the CAP's are now integrated into the Drivers since 13.1 i think it was, you nolonger need to install separate CAP's.
I would just uninstall the lot and reinstall the latest Drivers without CAP's.
I use 12.11 beta atm
Heard a lot of problems with the latest drivers and that the improvements from 12.11 to 13.3 are minimal
Have you used them yourself?
If i avoided a driver everytime someone said there are problems i wouldn't be using any.
Lucky for me i don't listen to what people say in that regard and i don't have problems with drivers.
While problems do occur with anything from time to time, far more often than not its down to peoples own stupidity, incompetence or its plain old bull manure..
Very true
