+4 million PPD for the team, I've never seen it that high, granted I haven't been here that long in comparison to many of you but surely that has to be a record, and what about team position, what's the highest we've ever been?
Unlocked multi yes only ES or Engineering Samples.
Voltage unlocked ES and HE's
Don't forget that I have the new motherboard on its way too![]()
Well you can up the voltages to help with any OC that you do manage to achieve.
You will need to use the OC bios from hardocp's forums and you are effectively overclocking by upping the fsb so having fast memory helps. Also you really need to put heatsinks on many of the motherboard chips once you start overclocking and have good airflow across the mobo as well as good cooling for the cpus.
Take a look at the guide here at hardforum where the OC bios for Supermicro boards was made.
Just remember be very careful when flashing the bios on these expensive motherboards you can brick the board by using the wrong or missing switches in the flashing tool![]()
Woohoo! I'm away in Spain for two days. But I have splooged a wad on 4 spicey somethings. But I'm gonna take my time putting the bits together.
