guest
guest
Hi folks,
Got a MSI 7950 TFIII BE and it idles at 500mhz and fully clocked RAM (I'll have to double check the RAM speeds later).
The thing never returns to 300mhz even with 0% GPU load.
I am running a single Benq XL2411T at 144hz via DVI-D at 1920x1080.
Any ideas?
I hope it's not another dodgey MSI!
But I won't jump to conclusions.
Catalyst Software Suite 13.1 1/17/2013 from the AMD site and I had a look around in the overdrive function and MSI Afterburner but set every thing back to defaults.
Just found this old thread:
http://forums.overclockers.co.uk/showthread.php?t=18454165&highlight=7950+idle+500mhz
Slightly different card but suggestions a driver issue then. I'll install the beta driver that AMD have on their site to see if that helps - failing that I'll manually adjust it in CCC.
Thank you LtMatt. Couldn't have asked for a better or quicker answer. I'll report back later after work.
A single 144Hz panel requires the same GPU bandwidth as multiple 60Hz monitors. It's probably not coincidental that they have the same idle clockspeeds. I'm looking into it, but I would not be surprised to learn that 500/1250MHz is required to avoid display corruption via insufficient bandwidth on the display PHY.
