you need to go to disk management and mount the drive (format + partition + name + drive letter)
Ok, it says its unallocated
the above is all that needs doing mate and everything should then be fine
what is your motheboard gigabyte z68ap-???
oh then you'll need to look for a make and model on the card and then go google the drivers for it
Tried putting network cable into motherboard but it didn't work. Don't even know make and model of card. Think it's old.
Probably get a new card then..
Perhaps. Shouldn't it work from motherboard though?
Only if the mobo lan(Realtek) driver is installed.
http://www.gigabyte.com/products/product-page.aspx?pid=3897#dl
Got it working in the end!![]()
I noticed after I had posted.
Glad to see you got it all sorted.![]()
Cheers, it appears to be still a bit iffy. I might get the lan drivers for my motherboard. ARe motherboard lans any better than network cards or are they all the same?
