Anyone else having hdmi audio issues running through an amp? Both the 13.4 and 13.5 betas break my audio. I'm guessing it's the same problem as pre 13.3 beta 3.
Same here. Go in CCC > My flat panel displays > Lcd overdrive, tick enable overdrive and amp should get audio signal, then untick if you want. Works for me.
Wish AMD could fix it and keep it fixed.
Check your trust PG Tips i can help with your Dirt Showdown problems for much less than old scrooge is asking for.
Legend, cheers bud![]()
Get some practice in, you'll be invited to the next dirt showdown ho down!
After installing 13.5+CAP i had to reinstall MSI AB,since it was locked on half clockes (13.4 same) and gpu temperature was weird at 36-38C
After reinstalling all seems ok again,clocks and temperature 28-30C
Got lil bit worried for are min about those new drivers![]()
CAP's are included in the driver are they not?
Thracks did say its better to always have the Cap installed aswell, his post is in this thread somewhere
http://blogs.amd.com/play/2013/04/24/new-134-135-catalyst-drivers/
13.5b2 is the latest code for all libraries.
For the record as well:
If a driver contains newer built-in profiles than the installed CAP, the installed CAP will be ignored for those entries. The driver will fall back to the CAP in absence of a built-in driver profile. The latest CAP is always suggested.
