And Skyrim juddering. It's not permanent but very annoying when it does flare up. I use CF but don't know if it's present in single GPU.
So looks like Trixx and the drivers 13.3 to 13.5 didn't get on with each other.Installed MSI AB and now running back with my old voltage again 1.131vSo looks like Trixx and the drivers 13.3 to 13.5 didn't get one with each other.
What OC you running at that voltage?
MSI AB beta? Or standard
Standard
1100/1500
Damn, i'm rocking like 1250v atm on my card at them clocks
Did the voltage readings get fixed? Before when i used it, it would read 1125v when i was running 1250v
It was Metro I was trying to run (well the benchmark) when I realised I needed PhysX.
I've currently only played Black Ops 2 and run the Heaven benchmark. Both seem 'off', I don't know I'd really call it stuttering. It might just all be in my head after reading about smoothness issues on AMD and frametimes and stuff.
I've been running the new BETA drivers for a few days now without any problems with my 7970s. BF3 is running great however I still have to set the mesh detail to medium as high/ultra just kills my fps.
Is this a cpu dependent thing?
