Moving from Nvidia to AMD - drivers
29 Aug 2010
Cornwall
Hi,
Not starting a thread to ask if I should switch, so lets not get into that.
My question is just if there's anything special I need to do with regards to drivers?
Can I just uninstall Nvidia drivers and install the AMD ones or do I need to run some sort of driver cleaner?
Thanks.
Hi,
Thanks.
Just done the same, easy as pie :-)
Uninstall Nvidia Drivers
Restart
Run DriverSweeper
Restart
Install AMD Drivers
Install RadeonPro :-)
enjoy
Nothing too technical to do. Make sure you use driver sweeper though. I switched to AMD recently without any problems.
Driver cleaner is really only necessary if you're having problems.
Maybe people have both AMD and nVidia cards in the same PC at the same time with no driver conflicts.
Because it's not a given that they will happen. Driver sweeper should be the last resort before re-installing Windows, as it can and does mess things up itself.
Driver Fusion is the one id be using, its the best of the lot and takes file backups and forces a system restore point to be created (assuming you have it enabled) before cleaning. If anything goes wrong, not that it should, you can easily put things back to how they were.
Normally i agree with you m8 but Driver Fusion has to be been a bunch of poo to me. Fragged up my windows install more than once. Where the older version called driver sweeper (developed by the same guys?) has always worked with no issues, even on beta versions of win 8. Maybe im just one in a million....like 4 times :P
I just uninstalled nvidia and installed amd drivers and it all worked OK for me.
Driver sweeper has borked windows 7 and 8 installs for me, but i used version 3.2.0 as that was all i could find. I understand there is a 3.3.0 version that works safely. If you have used 3.2.0 trying running a sfc /scannow command prompt scan and see if it can find problems its unable to fix.
I've always used 3.2.0. (latest i could find as well). Funny isnt it how "One man's junk is another man's gold" so to speak. I never ran any sfc /scannow. Everything worked so had no reason to. But i'll keep an eye out. Dont want to be caught with my pants down.
Just don't run sfc /scannow and you'll be ok. :p
