Don
 - 20 Oct 2002
 - Oxfordshire / Bucks
That 'region free' out of the box i take it?
From the bay or an enthusiast?
the bay
Ok.....atari has arrived.
dunno really
but I got a modded UK MK1 which does language selection and has a 50/60 hz switch too
Any Mark 1 machine that isn't VA6 or higher I believe. Basically the earlier ones have less integrated components and therefore better quality audio. The later ones use an integrated FM synth which doesn't sound as good. Opened my MD up to find out that it was a VA4 UK launch model from 1990!
Doesn't matter what region machine you get though as once the switch is installed (which is a three wire job and REALLY easy to do), you can switch between PAL, NTSC-M (America) and NTSC-J (Japan). It'll run identically to any other region machine. The only upside to getting a Japanese machine is that you can fit the larger Japanese cartridges in the machine but this can be overcome with a cheap as chips Game Genie or 32x.
Ok.....atari has arrived. To say I am amazed / extatic / over joyed is an understatement...
A bit of net research has revealed it is an original 1977 "sunnyvale" edition so its an gen 1 complete console!!!
Apologies for all the images, just had to share![]()
Does it come up with a licensed by or under license from Sega screen? If it does it's a later one with TMSS (Trademark Security System) which is a good way of dating the machine. You'll want to open it up at some point to install the modswitch anyway I'd imagine so you can check then![]()
also yes you can get the joypads you ask about. model is hss-0101
there has been a few on ebay lately ( everdrives ) but been fetching like you say 100 plus.
I hardly ever see any gameboys or consoles in charity shops so this is pretty rare i think to find something like this in one
Just bought a Super Gameboy for the SNES. Does it play Gameboy Color games or just the originals?
Any recommendations I should pick?
