Got what seems to be a dead 2TB Western Digital Green. But events leading to it seem odd.
Started last night.
I was browsing and got multiple bluescreens. Then my Vertex SSD was no longer detected in bios and when this happened it was blinking red. Apparently this means it's panicking or something.The couple of times I was able to boot, the 2TB seemed fine and could be accessed.
On to today, when I've tried to sort everything out.
To cut it short, everything now works fine when the 2TB is not connected.
2TB connected, SSD refuses to load Windows.
2TB connected with windows on a Mechanical drive, loads slowly but the 2TB is not accessible. It has a drive letter, and that's it. Drive management won't load while it is connected.
2TB connected to another working pc, same deal. Loads, 2TB is not accessible, but as the other pc has never had this connected before, it moans that drive installation for "model number of drive" has failed. Letter is assigned, but that is it.
2TB shows in bios.
If you put your ear up against the 2TB, you can hear it spinning and the occasional thud sound. So I assume it's dead. It also seem to make a buzzing/click sound earlier, but has not done it since.
So it would seem that it's dead.
So question is, why is the 2TB apparently dieing, cause for bluescreens and the SSD to panic? Or am I overlooking something and something else is at fault.
			Started last night.
2TB shows in bios.
