Hi all,
You seem like a knowledgeable forum - and I was hoping you could help me out.
I'm working on some research, that research requires doing a lot of number crunching on ~55GB of data. To make this process as quick as possible, all that data should be in memory. A vast majority of the work it's doing is on floating point numbers. This'll be an iterative process running over several weeks.
I've built a few machines before, although only AMD. I thinking an Intel CPU might be better for this job.
Graphics are not important, and it'll only be dumping a few GB of results to disk every 24 hours, so I'm not that fussed about the drive either. As an afterthought - this machine might eventually become a development workstation once it's done number crunching.
I'd like to spend as little as possible (doesn't everyone), ideally <£1000. Putting together a few pieces as a starting point (And I'm already over budget):
Intel Core i7-3820 3.60GHz (Sandybridge-E) Socket LGA2011 Processor - Retail
2x Corsair Vengeance RED 32GB (4x8GB) DDR3 PC3-14900C10 1866MHz Dual/Quad Channel Kit (CMZ32GX3M4X1866C10R)
Asus P9X79 Intel X79 (Socket 2011) DDR3 Motherboard
Western Digital Caviar Green 1TB SATA 6Gb/s 64MB Cache - OEM (WD10EZRX) **SINGLE PLATTER** HDD
Cooler Master Elite Power 500W Power Supply
Xigmatek Asgard Midi Tower Case - Black
Sapphire HD 6450 HM 512MB GDDR3 PCI-Express Graphics Card (11190-04-20G)
Microsoft Windows 7 Professional SP1 64-Bit - OEM (FQC-04649)
£1,159.91
Thanks in advance!
£1,159.91
Thanks in advance!
