Looking for new build
10 Sep 2012
Hi Guys,
I'm looking to get the possible best build I can get with my budget of £1000. That only includes the PC itself not a monitor or any other hardware like mouse/keyboard. I already have the AMD ATI 7850HD Power Edition GFX card so not really looking for another GFX card.
I'm looking for an i7 build as I tend to stream, play games and also do 3D rendering. If anyone can point me in the right direction that would be great, I've been out of the PC gaming scene for awhile and lost track of current hardware and want the best I can get with my budget.
Forgot to mention not looking for a watercooling rig, i've never built one beforehand and really don't want to attempt to build one untill I read up more about it.
Also all the parts in my rig right now are extremely old so I need everything replaced apart from my GFX card. I'm willing to spend upto £1000 so if you could find me the best parts upto that budget that would be great, I was looking at i7 3770K.
What's that sandwich case CD thing lol, only thing is on the basket you have provided it's for watercooling and i'm not looking to build a watercooling system yet :(
It's not a proper watercooling system, it's prefitted, you just attach the heatsink as normal, it's a contained system, it just links up to fan and radiator by the exhaust fan of the case, dead easy to fit and makes case tidier.
Also that sandwich case is ABSOLUTELY ESSENTIAL you cannot run a PC without it, ask anyone on this forum and they will agree!:D
Would you recommend going for i7 3770k or go for saocket 2011 now instead of 1155? Also regarding all the ram choices which would be the best option gaming wise aswell as rendering wise. I'm willing to spend a little extra on a more advanced Motherboard aswell as Ram also if you could link me the difference between items listed? Thanks guys really appreciate the advise and still open for more options if possible please.
Looking at what others have said, I would go 2011, I didn't think about that earlier, also dual/triple channel DDR3 at a decent clock, 8GB should be ok but you can spend a bit extra and go to 16GB if you wanted :)
