You buy the song on Google Play and it will sync to your Google Music Web Player and Google Music Mobile app.
Use Music Manager to download the song to your PC harddrive if you'd like as well as upload your already owned music to Music Google
Then in the Google Music app on your phone you can "Pin" the songs/playlists you want to physically store on your phone for when you don't have a connection to stream.
If the songs aren't updating on the app, go to settings and press the Refresh button to make it check if your music has been updated.
. Cheers again!PA has a quick reply and a pop up option for SMS.
Really is an awesome rom that PA and i cant wait for the upcoming killer feature.....
Google Music is the dogs curlies!
PA is built from CM repositories, so it's a CM feature![]()
PA is built from AOSP![]()
Some things might be cherry picked from CM but vice versa there too CM take things from PA![]()
I was just looking at their Github, which is forked from CM
Aside from Pie Control and this overhyped Halo feature coming up, most of the stuff in PA is from CM!
 it used to be based off cm.You forgot to mention Hybrid Engine (allows multi dpi and layout changes)
 I spent about an hour messing the the dpi for all my apps to see what they looked like.That'll be the Samsung one. Try the nexus![]()
 I think photoshop has an S3 anyway..
.I thought I was in the S3 threadI think photoshop has an S3 anyway..
What music players does everyone use, could do with something with a nice small widget if at all possible?![]()
