Flood – 70W Day White
Great find, Westy. I've been looking for something like this. Care to provide some searchable info to your seller?
Paid £66.99 from eBay.
All prices in that post are links.
Done some searching:So after my previous success, I'm now after some more bulbs.
This time it's regular screw-fit E27 (Edison 27mm) in the classic shape, rather than GU10.
Current bulbs are 1200 Lumens, and are 97mm high by 56mm wide.
Anyone know a good LED replacement?
Can definitely recommend this type of light. I have 2 x 30w warm down the side of my house fantastic light.
These Cree bulbs sound good, doesn't seem to be any uk retailers though
http://www.cree.com/lighting/products/indoor/lamps/60w-replacement-daylight-type-a-led-bulb
Anyone tried the TCP brand GU10 bulbs? Looking to get 7 for the kitchen.
http://www.tcpi.eu/product/view/LEDGU10
3000K, 250 lumens, CRI 80+, 30 degrees beam angle. How does that compare?
Is that both lights mounted in the same spot?
Having looked around I can't find a cheaper floodlight - I think I'm gonna buy one no matter what my dad thinks!
Not a huge garden to put them in but 2 x 30w? or 1 x 70w?
Tough choices![]()
You can't use led bulb in the oven, IT HAS to heat resistant lamp.
Fridge: http://www.ebay.co.uk/itm/E14-LED-Pygmy-Light-Bulb-1-2-Watt-LED-SES-Daylight-6000K-/181051575756
Oven: http://www.ledbulbs.co.uk/25+watt+p...)/3642663686?gclid=CKD-yov4jbcCFWLHtAodZhQAOg
