*** NZXT H630 Silent Ultra Enthusiast Tower Cases ***
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys!
Available now for pre-order! The new H630 Case from NZXT, they offer a new great style from the famous NZXT manufacturer!
NZXT H630 Silent Ultra Enthusiast Tower Case - White @ £129.95 inc VAT
Beautifully architected, the new H630 is designed for two primary purposes: provide enthusiasts the ability to build the highest performing systems while remaining audibly invisible. With its incredible ability to subdue component noise, games, videos, and music take center stage of the system’s experience.
To help combat contaminating noise pollution, the H630 brings its owner several innovations. The H630’s insides are lined with high-density sound dampening material while the front of the enclosure is the first of its kind to support twin 200mm large fans. With their size, the fans spin at a silent RPM while pushing large volumes of air. Meanwhile, vents are intelligently positioned to lower intake noise. The H630 also provides exceptional support for a wide range of cooling solutions, including the ability to install 240mm, 280mm, and 360mm radiators.
The H630 utilizes a closed-cell, high-density foam which is the most efficient solution for silent computing. With seven millimeters of this premium sound dampening solution, the H630 is capable of destroying component noise without hindering performance.
The H630 offers the best water cooling support of any silent chassis period – Capable of supporting a 360mm radiator in both the front and top positions without any modifications.
The H630 is the first chassis in history to support two 200mm fans in both the front and top positions. With fully modular hard drive cages, the H630 offers unrivaled airflow capabilities. Unlike much of its competition, the H630 offers maximum airflow expandability without the removal of any sound dampening material.
- Dimenions: 245 x 547 x 567mm
- Material: Steel / Plastic
- Motherboard Support: ATX / mITX / mATX / XL-ATX / EATX
- External connectors: 1 x Audio / 2 x USB2.0 / 2 x USB3.0 / SD Card Reader / LED on-off
- Bays: 2 x 5.25" External / 8 x 3.5" or 2.5" (2 behind MB tray)
- Front Cooling: 2 x 200mm ir 2 x 140mm or 3 x 120mm (1 x 200mm inclided)
- Top Cooling: 2 x 200m or 2 x 140mm
- Rear Cooling: 1 x 140mm or 1 x 120mm (1 x 140mm included)
- Bottom Cooling: 2 x 140mm or 2 x 120mm
- HDD Cooling: 2 x 140mm or 2 x 120mm
- Max CPU Cooler height: 190mm
- Max VGA Card length: 354mm
- Cable managment space: 27mm
- 2 Year Warranty
Only £129.95 inc VAT.
ORDER NOW
NZXT H630 Silent Ultra Enthusiast Tower Case - Matte Black @ £129.95 inc VAT
- 2 Year Warranty
ORDER NOW
Will be going for one of these, hope there will be a window panel coming out.
NZXT do seem to be good at releasing windowed panels.
I won't be looking at replacing my phantom for a while. But if I were, this would be a serious option :)
Will you be sending one of these to Stulid?
Would be great to see what he thinks.
Come to think of it, I could drop the wife & kids at Puxton Park and nip round while he tests it :D
Send me one ace and I promise to fill it with radiators!!!
I quite like it, simplistic yet feature packed.
I think they look fantastic, although that angle doesn't show it in its best light...
how long until we get them in blue, orange, red &....pink? :D
Is it a brushed alu case?
I'll take the black one if its got a brushed alu exterior :)
It's painted steel
Very nice perhaps not as funky as the switch and phantom but very nice all the same I can see some gorgeous build coming from this case
I've seen some pics of this kitted out with a pair of 360 radiators. Looks like we have a new budget wc king of a case, move over 810 :D
Looks an awesome case, if I go to a white case, this will be my decision maker.
Only thing that worries me is the front is blocked off pretty much, so airflow is limited, i'd rather a solid flow of air coming through the front, than limited vents. The Corsair xxxD cases I was put of with because of that type of design. I know that it keeps it silent, but things get toasty quicker using the back fan as the only major intake.
Nice looking case, but I wonder if you stick a 360 rad in the front, is it going to be able to suck enough air through with the door shut.
Nice looking cases - I am guessing the fan controller pictured on the front of the white version is an optional extra as it isn't featured on the black one.
Anybody know what model number it is if it isn't included??
That's a Maelstrom bay res, if you look at the rest of the pictures you'll see that there is a watercooled X79 system built inside it to showcase it's watercooling potential :)
Could be seen as being a little misleading though, since it is the main product image and all.
Ah I wondered what that was and should have spotted the pumps being fed out of that bay when I was browsing the gallery.
