- 21 Nov 2005
- Cornwall
Actually, wore my belt much higher than usual today, which felt far better than previous weeks, and helped me brace my core more effectively.
Will doGo mixed grip from ~140 onwards, and video everything.
The first rep always feels the tightest. I don't feel like I have to think about bracing or tensing anything once I've got the weight up because I know I'll be able to rep it. First rep almost feels forced and unnatural compared to the rest. Perhaps I'm over thinking things for the first rep?With regards to the first rep being harder than the others, my theory is that the negative allows you to be much tighter for the second rep therefore more power ends up going into the lift rather than into stabilising weak areas.
If that's the video where he teaches you to brace your core, pivot at the hips and then bend at the knees I tried that a few weeks ago at 195 and it turned in to a hump back SLDLYou might want to consider doing a Kelly Starret-esque set up as that encourages much more tightness throughout.
I can't see that although I'm not great at judging technique. Is there anyway you can do a frame by frame comparison on YouTube?Also look at the difference in line and joint angle of the hip and knee on the first and second rep when the bar is 6 inches off the ground. Your hips rise too quickly on the first, the second is a much cleaner rep.
Nope, usually finish warming up around 30kg off my working sets for squats and deadlifts.Did you do any other reps between 175 and 205? Seems strange to leave a big jump to the end of warmups?
This the sort of thing I should be looking at?It does look like your missing a bit of internal rotation in your shoulders, something to look at.
I do track the bar on the way down although I'm not 100% sure if I lift my head to do that or just follow it with my eyes. Does look like my head position moves slightly during reps two and three though. Could've been chin tucking.Does your head come up on the bench press?
