- 3 Jun 2005
Will do. Cheers for you help.
benjo, i tried ur method above and had no change. BUT, i probably put the file in the wrong place.
.Benjo, is it supposed to be /system/data or /data? You've said both so far.
Whoops, my bad.Carmageddon is going to be available free tomorrow only![]()
I "purchased" it on iTunes when it came out on iOS (when they did the same promotion), despite not currently owning an iOS device, just in case I decided to get an iPad at any time! How cheap am I...?![]()
Using your file explorer (need to be rooted), go up as many folder levels as you can until you reach your root directory, probably just called /
There should be a data folder in there![]()
yeah that's where I have it and its not working for me.![]()
Hmm, I'll have another proper look into it tonight. I'm sure there's a way to force apps to stay in ram.
I'll update once I find something that works![]()
