Catalyst control centre removal
11 May 2010
Just having problems getting a definitive answer by googling , some of these are years old .
I need to remove CCC and the graphics drivers for my hd5850 , I'm going with Nvidia .
Is the only way to remove ccc through add remove programs ? is that the same with the graphics drivers . Sorry , I'm just not that techie when it comes to this stuff but can get on and do it . I need both gone before installing the Nvidia drivers .
Cheers .
It's called amd catalyst install manager in programs & features. Theres an option there to uninstall all AMD software or you can go custom and pick/choose if you need to. (for example, if you have an amd processor with amd sata drivers)
Cheers .
ATI uninstall tool in add/remove programs then driver sweeper.
I checked on that and it asked if I wanted to install it . Silly question I know , but should I install it and then it will uninstall itself when I click to uninstall all amd software ?
