I have the same, and have tried a US proxy to see if I can enable it. However predictably once you connect with a US proxy you need a US registered credit card to get access.
Yep just tried to get onto it but no way of paying for it
Just like all those Mp3s you have on Google Music - be good now!Make sure you have the appropriate rights to the uploaded content.
Hangouts app available on link below (though doesn't work on Nexus 7 yet according to the comments)
https://play.google.com/store/apps/details?id=com.google.android.talk
It hasn't been confirmed if the GS 4 nexus will be using the snapdragon chipset yet (AFAIK anyway), there is a small chance that it could be the exynos version (the Korean version supports LTE).
I'll be shocked if it isn't the snapdragon version though...
99.99999999999999 % It will be Snapdragon![]()
Exynos isn't open source and Samsung has always been cagey about releasing documentation about the chipset.
Developers have been campaigning for ages without much success
http://forum.xda-developers.com/showthread.php?t=1925709
Unless you have the i9500 version I don't see why this would be depressing. AOSP By google means devs will have the sources needed to build a perfect CM 10.1 & AOKP rom.
No confirmation of AOSP support yet. Just stock Android. There is a difference (see the I/O Tab 10.1 - stock Android but not AOSP.)
If it's Snapdragon, AOSP support will be nice but not critical thanks to CAF. If it's Exynos, AOSP support will be a gamechanger.
Regarding the stock android GS 4:
http://forum.xda-developers.com/showpost.php?p=41452293&postcount=34
Can someone explain what the difference is?
Guessing that it is pretty important??? At least when it comes to getting the latest update quickly without bugs/niggles anyway??
Hey,
I missed the first hour of the keynote - is Google Games actually going to be an app like Apple's Game Centre, or is it just the backend for game save syncing etc?
If it's an app, when can we get it??
Cheers,
Su
Good timing![]()
If this forces Google to fix sd cards being the <John Snow> child of storage for once and for all I welcome it. Infact, I want to see how they clear this up and hope they don't just do the usual ignore and slap it in a nested folder crap.I am a bit confused. Will the s4 with stock android have the SD card ?
