**THE NVIDIA DRIVERS THREAD**
2 Jan 2012
UK.
The Latest:
http://www.nvidia.co.uk/Download/index.aspx?lang=en-uk
NVSlimmer
https://www.guru3d.com/files-details/nvidia-driver-slimming-utility.html
Download the NVIDIA driver slimming utility, it is exactly as it says so you can trim down your NVIDIA driver install base.
As described by the programmer uKER , having trimmed NVIDIA drivers for as long as he can remember, the man decided to make a utility to help make the modification and installation process more bearable. Now, this idea has transformed into an easy to use utility usable for the general public. With the tool, you can select the many modules that form the driver, and select what you need and/or want to be installed. Once you hit apply, it deletes the modules the user didn't choose, and offers the option to install the driver. The app is in early staged and will likely see some updates and improvements. Hope you find it useful. Any bug reports and/or suggestions are welcome, you can check out the dedicated forum thread where the author is active.
Nvidia GeForce Experience:
Just to stick my head in here and give you a big thumbs up :)
Feel free to steal anything from my thread thats of use to you buddy :)
What would be very useful is when a new driver comes in you could update the first post with a link to the post number where discussion started about that driver.
Anyone get any crippling fps drops to like 1fps and couldnt recover on planetside 2 on 320.00 beta drivers. I have so just rolled back to 314.xx ones in hopes that resolves ps2 fps issues. Tho the physx driver wouldnt go back to the 314xx version i think it kept the 320.xx ones. CPU was no more than around 45-48c and the gpu was at 50c so there wasnt any overheating issues plus my windows open and its a bit nippy tbh.
