- 28 May 2007
I just sent an oced Titan round the block in Heaven 4 using the same settings
I can oc the card higher but could not be bothered, my CPU was at 4.0ghz for the same reason
All I can say is they must have been using a pretty awful Titan as mine individually are not the fastest.![]()
It could be a driver issue or something as there titan was boosting to 1162 which is pretty good. With these clock speeds you would expect a much bigger boost in performance than the 5% they got.
