 - 15 Feb 2009
 - Bristol
I thought it would be much easier to keep track of my progress making a log here rather than trying to remember what I've done!
I've been on and off (mainly off) with basic weight lifting/running the past couple of years but really want to shift the fat/gain strength.
Just half a year ago, I went through a rough patch, where I went from 155lbs to 170lbs in the space of about 3 months
 and because I play a lot of badminton, I can really feel the extra weight moving around the court.
Because of that I'm mainly looking at getting lean again, rather than making serious strength gains, but hopefully I can still see progress with my workouts.
I've never logged my workout sets and reps before yesterday so it's very experimental with the weights atm.
But here's what I did yesterday (chronologically; I was there for about 1.5 hours):
Rope pushdown - 80lbs to 140lbs in 10lb increments 5x5
Pull-ups - 2x4 1x3
DB curls - 12.5kg 5x5, 15kg 2x5 1x2
Lat raises - 7.5kg 3x10
Hang clean - 40kg 4x5 1x2
DB shoulder press - 10kg 1x5, 12.5kg 5x10
Rope pushdown - 150lbs, 130lbs & 100lbs 1x5, 80lbs & 60lbs 1x10
Then I normally finish workouts with stretching and crunches.
Any advice or suggestions is much appreciated. Like I said, I'm fairly new to all this so anything you say could be new information and be really helpful for me.
Starting Stronglift 5x5 (23rd May 2013)
Starting stats:
Height: 5' 10"
Weight: 170lbs
Squat
80kg
Bench Press
45kg
Barbell Row
55kg
Overhead Press
40kg
Deadlift
100kg
 and because I play a lot of badminton, I can really feel the extra weight moving around the court.Because of that I'm mainly looking at getting lean again, rather than making serious strength gains, but hopefully I can still see progress with my workouts.
Pull-ups - 2x4 1x3
Starting stats:
Height: 5' 10"
Weight: 170lbs
Squat
80kg
Bench Press
45kg
Barbell Row
55kg
Overhead Press
40kg
Deadlift
100kg
