Best monitor for £150
24 Dec 2010
Anglesey
Hi, looking for a monitor that can connect an Xbox, PC and the upcoming ps4. I would like to connect all these together without having to switch any cables around. I have £150 to spend will add another £10 if its worth it.
I have seen Asus VE247H for £142 it seems pretty good, but would like to hear what you guys think.
Thanks.
Edit: next month I'll be buying, don't have the cash right now.
Just looked at it pryere, specs sound decent but not fond of the make.
The Asus looks better and its a tad cheaper :)
Do all these standard sized monitors from 19"to 24"have in built scalars and can display bios etc?
Bought a VE247H in December 2011 and I love it. Bought another two past month and they're shocking. Has a strong tinge of yellow. Seems like people on Newegg are reporting the same problem.
The firmware on the two new monitors was different so it may be a problem but I guess you could return it if you find the same problem as me.
