White knight build update time
on the back of the tray - but the 600t comes with a detachable caddy that can be screwed in at the bottom =) I could stick another 120mm rad on back but no need =)
how often do you guys use the 5.25 bays? and is the use of removable data worth losing the extra cooling when we have cloud storage?
İf you look at my pic, you notice the fans will pull air into the entire case =) everything will get cooled from the air let alone the watercooling =)
Er might have to re-think. Have the mobo in the case, the stealth 360gt doesnt even really fit that well, but the only way would be to mount the fans on top which i don't want to do.
I'm guessing the 480 on the bottom wont be enough?
Since this project has been a slow process since living in 2 places i might just hold out for the 900D now and put my old rig in the TJ07.
Any thoughts r welcome
A new edition today put together yourself job :D
Nearly ready just waiting for the 900D to arrive!
Might add a second and use red and white pastel colours for the loops.
So many changes to this build but nearly there!
Some serious hardware! Consider using 1/4 to 1/4 threads if you are having problems with the tight connections. Sometimes it works better to use only fittings rather than such a tiny bit of crystal link tube etc. Look forward to seeing some more :)
lol I didn't know what you were talking about until I looked closely at the second picture :D
hope you are going to get another quad set of ram ;) empty slots? preposterous!
This is looking sweet Alex. Very nice looking in white and that tubing is awesome :)
Very nice gesture to give away a 680 and water block. I will help get it boosted ;)
