Was i mad? VTX3D 7990 faulty from the Bay
I have a Water-block from OCUk on its way for it as well, though i will test the card extensively first to make sure its only got the problem described otherwise its going back with avengeance!
It says Bottom DVI port does not display, Question is... Is that the Dual link or the Single Link?
According to this picture of the same card:
The top DVI Port is labeled DVI-D and the bottom DVI port is labeled VCA.
Am i correct in assuming that the top is the DVI Dual link and in turn is working?
I use a DVI-D and DP at the moment for my Catleap and Hazro monitors, so its very important that the DVI works.
Oh and i wont be using it along side my DCII 7970, the Sniper M3 motherboard wont allow a Dual slot card at the bottom. That is a reason why i jumped on the 7990 tbh.
Will update as it arrives
UPDATE:
So it arrived this morning.
Here are the un-boxing pics
lets see the card
Looks in good condition, i see no finger prints or signs of use at all Though we know its been used as it was "tested"
Will see which of these actually works later on in the week - no time today due to ipad repairs
Oh look what else turned up
That is the BIGGEST Waterblock box i have ever seen!
One MAHOOSIVE Block
And the same can be said for the back plate
the underside
When i get the time i will test the card on air and if i can get it working via Display ports or DVI and both cores work and don't artifact or crash then i will watercool it
EDIT: TESTED
So i got around to testing it. Was a right pain getting it into the case with the 7970 still attached. I didn't fancy draining any loops today.
Here are some random pics for the fun of it
Moved the 7970
In goes the 7990
NOOO no display with the dvi with the hazro
Plugged the Hazro into a Dell Adapter and the Catleap into the DVI
And W00T!
VTX3D AMD Radeon HD 7990 Graphics Card (FAULTY)(A7-L-019-AP)
BOX: Original box
ORIGINAL PACKAGING: Yes
ITEM CONDITION: Used
PARTS MISSING: No
Unfortunately due to the nature of the stock we receive, we are unable to determine the exact accessories or parts included. the accessories/parts included are: Item is complete
AMD Eyefinity multi-display technology
AMD App Acceleration
AMD HD3D Technology
AMD CrossFireX Technology
working, but bottom dvi port does not output any display. missing one dvi to hdmi adapter. works fine through top dvi port and hdmi port. all other accessories present
most of our items are sold for parts or not working/spares and repairs or with some fault or defect. please read our listings carefully before bidding.
Due to the testing procedure there may be other faults found which we are unaware of so please bare this in mind when placing a bid.
This item is for auction only, we do not offer a buy it now price for this item.
UPDATE:
lets see the card
One MAHOOSIVE Block
the underside
EDIT: TESTED
Moved the 7970
In goes the 7990
And W00T!
