it's a competition not a charity. Isn't it?![]()
If this competiton were a charity it would be called
'The - give PC parts to someone who already has a potentially better PC - fund'
Instead set a lower time as a target to hit. This will require just as much knowledge about overclocking and tweaking because you will have to be carefully adjusting your speeds and timings, but you will get more attention and entries because it is a feat that far more people would be able to achieve.
Core i5 2400
If it was lowest time, on any kit with any configuration I could see peoples grievances.
But it is limited to 4GHz and thus shows who can get the MOST from a 4GHz clock, which leaves other things than JUST core frequency alone to play with. The sort of people who will enter this should be able to attain a 4GHz clock very easily with almost all of the last few years worth of kit. You do not need to be cutting edge.
Yes you do. A 4Ghz 3570k is faster than a 4Ghz 2500k all else being equal. Both would destroy an AMD CPU. Same applies if you already have much better RAM to begin with.
I appreciate them putting competitions on but this really is only for people that already have the best kit. I won't stand a chance with the RAM that I use.
I am sure there is much tweaking I can doThe majority of people here have Steam installed, right? I know a hell of a lot of people have Steam installed, but it does make you think, most people who can run 4GHz Stable, would do right?
Maybe the winner should give his existing core system to someone with a slightly worse one, and so on, so everyone gets an upgrade?![]()
Well you lot just keep arguing about it and don't enter, that way theres more chance that ill do well.
here's my first submission with a totally unoptimised system, assuming we are allowed more than one entry when we improve our times. (it didn't say only one entry per person so I assume that it is ok to improve)
already a minute behind Tonester oh well.I am sure there is much tweaking I can do
http://imageshack.us/photo/my-images/29/32msuperpi1.jpg/
You're technically winning as i never bothered to change my wallpaper lol, so my entry is invalid. There's hope for you yet! If everyone continues to moan about never having a chance, you might win
Edit: Kaap ruined your chance! Damn you Kaap!![]()
