Wish I'd seen your post earlier, Sarge! Link the shop, please.![]()
My god, it was like I was skinning myself alive!Thanks for that Sarge - found the shop and placed my order with free delivery and 30% off = it's all good![]()
Is it Beauty at Creightons?
(might not be the best for guys with sensitive skin)
You really need to hit youtube and do some research on technique. Plenty of advice on there. Perhaps start with
Mantic59
If you have a white ring of old soap/cream at the base, that is probably the cause. lather up with washing up liquid and put the brush in a glass of water for a few minutes, then rinse it. put in in a glass of water with white vinegar (i use about 20% vinegar), leave it for a few minutes, then rinse and let it dry. once dry, repeat if the white ring is still there.
is there an out the tube / pressurized can of foam that people rate?
Distilled vinegar
The term "distilled vinegar" is somewhat of a misnomer, because it is not produced by the distillation of vinegar, but rather, by the fermentation of distilled alcohol. The fermentate is then diluted to produce a colorless solution of about 5% to 8% acetic acid in water, with a pH of about 2.4. This is variously known as distilled spirit or "virgin" vinegar,[6] or white vinegar, and is used for medicinal, laboratory, and cleaning purposes, as well as in cooking, baking, meat preservation, and pickling.[7] The most common starting material in some regions, because of its low cost, is malt. In the United States, corn (maize) is the usual starting ingredient for most distilled vinegars, such as Heinz.[8]
I bought some of the St. James cream, unfortunately i get the same reaction to that as i do to TOBS cream, so Creighton's must use the same base..
That rules out virtually every UK cream then! T&H, TOBS, Trumpers, Harris, Simpsons, Bodyshop, Castle Forbes, Salter, RS, natural grooming, bluebeards and probably a few others.
Here is what came today from the above mentioned place. They managed to send me some balm stuff instead of some no10 shave cream but not too fussed. I look forward to testing it.
Does the Cologne Balm have a light hand cream scent too?
It's probably triethanolamine, that's the only potential irritant left in Creightons base (assuming it's not a synthetic found in the parfum/fragrance)
Gutted.That rules out virtually every UK cream then! T&H, TOBS, Trumpers, Harris, Simpsons, Bodyshop, Castle Forbes, Salter, RS, natural grooming, bluebeards and probably a few others.
I think the only parfum free versions are T&H ultimate comfort, Simpsons luxury and Castle Forbes (although they do have a few extra basic scent modifiers)
Why do we always pay more for less?![]()
