What?!
Forza, Halo, Fable
Are you mad? There's 3 reasons to buy one right there!
That would be one of the best launch lineups in ages, it ***** all over both last gen consoles.
I'm sure they won't be (Halo 5 in particular) but if it's in the launch window (first 6 months or so) then I'm happy. As long as there's a couple of games I want at launch then I count that as a good launch.
What?!
Forza, Halo, Fable
Hmmmm...
If that list is true then it's hardly going to "kill Sony" at E3.
I am looking forward to HomeFront 2 though.
Got a link for that? Got to be false as the GPU isnt that cutting edge especially for AMD, perhaps its the custom mods or all those transistors that are causing yield issues? I dno sounds like rubbish at face value...In other news there's also more new rumours about production problems with the Xb1, including several people claiming that the GPU has had to be clocked lower than initially expected, and putting it at now around half the power of the PS4.
http://www.neogaf.com/forum/showthread.php?t=576869Got a link for that? Got to be false as the GPU isnt that cutting edge especially for AMD, perhaps its the custom mods or all those transistors that are causing yield issues? I dno sounds like rubbish at face value...
ps3ud0![]()
They aren't the same. All the rumoured problems with Xb1 are related to the eSRAM.Why would their be an issue with manufacturing the Xb1 and not the PS4?
Their both almost the same, sounds like some people are fishing for controversy. Plus it would mess up developers having to change it now.
