My new haswell build finally upgraded from q9550. I chose a 4650K in the end and a gigabyte Z87-UD3H with 8GB of Kingston HyperX Genesis Grey DDR3 PC3-15000C11 1866MHz
VID is 0.8250v
So after building my temps at idle were between 30-33C on all cores.
I then overclocked to 4.6Ghz to see if it would be stable at stock voltage and it is, but its a bit hot when running Prime64, cores are now around 83-89C
So I delidded using the Vice method worked a treat. I have then put Prolima Tech PK-3 between them all a thin layer.
After starting up and running prime again I am still getting 83-88C
So what thermal compound should I use between the die and the cover as I think the PK-3 is the problem. Or is 4.6Ghz just to fast for a Haswell.
Will try and post the photos of it all later
Advice welcome.
Happy the de-lidding was successful
VID is 0.8250v
Advice welcome.
