Hi Guys, hope you can help me with my bizarre problem.
I spec'd and built a machine for my boyfriend, it's about 2 weeks old, ran fine for a few days running under load perfectly fine but recently every few days it will decide to just shut down suddenly then switch off and on before it even gets to POST, and just cycles, sometimes getting further along then dying again.
Found the only way to cure it for the allotted few days is it re-seat the RAM, doesn't matter in which slots either.
Now obviously my eye is it being the motherboard at fault, it's just with it being so intermittent I'm unsure of it being something else and wondered if any of you have any ideas? Or ways I could pin down the issue.
I work as an IT Technician so have asked my friends in the field and they too are unsure, also thinking either the PSU or motherboard.
Here is the rig spec:
Corsair H55 Hydro Series CPU cooler
Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W)
EVGA GeForce GTX 660 FTW Signature 2 3072MB
ASRock Z77 Fatal1ty Professional Intel Z77 (Socket 1155) DDR3 Motherboard
Corsair Enthusiast Series TX 850W V2 High Performance '80 Plus Bronze' Power Supply
GeIL Black Dragon 16GB (2x8GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit
NZXT Phantom Enthusiast USB3.0 Full Tower Case
Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache
Samsung 128GB SSD
Windows 7 Pro 64bit
If any of you could help that would be great! When it's running it's awesome, but obviously a bit worrying with over £1000 worth of kit it to keep randomly dying.
Thanks
Natalie
Samsung 128GB SSD
Windows 7 Pro 64bit
Thanks
Natalie
