- 9 Oct 2009
- United Kingdom
Hmm Mine is running 4.5 @ 1.25 volts but seems to be hitting 77c. It idles around 30c.
I am running my first custom water cooling loop so was expecting better temps. I wonder if I need to re-seat my CPU cooler as my GTX 470s are running at 30c idle and 45c load which is a lot more acceptable.
I did the Asus test on my Gigabyte OC board, booted into Windows but crashed on Prime. So 4.6 might be possible.
this is haswell... using TIM under the heat spreader, there is only so much that cooling can do - to get good temps you need to delid the CPU and cool the chip directly
I'm actually running on air with a Noctua NH-U14S, and I'm wondering if something that big with it's own backplate actually squeezes the CPU slightly and makes especially good contact by squashing the glue and putting pressure on the centre of the heat spreader.
Silly question, what kind of UNCORE settigns should I be settign in relation to the normal CPU settings?
For example: Basic overclocking is to ramp up he multiplier say 40 for i5-4670K, should the UNCORE multiplier be 34 (stock), 39 or 40?
It does seem that lowering it a bit can help getting the overclock stable.
For 4.2-4.4ghz oc 2 multi down for uncore is fine 4.6-5.0 3-4 fine. Its diminishing returns. At 6.7ghz, uncore of 5.8 is enough for max bench scores.
I seem to be getting software startup errors on the MSI x87 g65 gaming; the 4.3oc passes all stress tests and runs rendering apps...but the killer lan software crashes on startup and causes a runaway cpu thread until shut down in task manager.
