Oooooohh! BTW you were featured on LTT Build log of the week.
Jealousy is a bad thing I know......but I do have some serious "I want it" issues with parts of this build!
Thats why I stuck with a serial loop.
That copper logo is just a sticker mate. They peel off very easily.
+1
"rad -sticker" looks a lot better than that grey sheet
overall very impressive!
 I'll have to touch it up with a little paint and hope it isn't too noticeable.
Yeah, that paint isn't the toughest...
I managed to peel a bit of it off when I removed a foam gasket.
Personally, I think it looks better with the rad on show and the copper sticker looks fine
Also, if you're going to put a window in anyway, you could just start it where the rad ends.
How were you planning to mount the plexi?
Behind the panel with u-channel, flush, bolted on the outside or something else?
I've been working on tidying the build up a little and here's the progress:
I definitely wanted to cover up the top section as it was a complete mess, I was also contemplating covering the rad and fans - mainly due to the copper logo on the radiator not fitting in (either cover it up or paint it silver).
