- 21 Jun 2006
Is it worth getting a dumbbell set?
I'm starting to do more dumbbell work which I do with oly dumbbells. They're ok but a bit cumbersome. I might just buy some more 5kg plates and load them up.
oly dumbells imo are the biggest pain in the **** i have ever seen, they are also imo when you get up to the bigger weights on them completely unsafe, your movements are a lot faster, varied, etc with dumbell work and i wouldnt like that much weight being suspended near me at a dodgy angle with a spring collar for protection.
Did you manage to get much of a discount buying them all at once? I Just want the sets 12.5kg-20kg and 22.5kg-30kg
get ironmasters
http://www.valleyfitness.co.uk/Adjustable Dumbbell
as above ironmasters are the cheapest way to have a full dumbell set at home, you can then add to it to get a kettlebell kit, etc, etc.
so if in 2 years time you fancy owning a full kettlebell set, it will cost you peanuts to do so, as you simply use the ironmaster weights in your kettlebell handle.
ironmaster are a solid company do not go for the cheaper imitations, i cannot remember their name but they are crap.
i have a full dumbell set which i bought second hand, had a set of ironmasters came up second hand i would have preferred them but most people who buy them don't usually sell them on because only well informed people know what ironmasters are.
