- 13 Jun 2011
Run BF3 with a single card, report back the GPU usage and frame rates.
ive only just installed the second 7970 but before I was getting 99% usage
will try again with one card once bf3 is reinstalled
any help is appreciated tbh, ive just tried again dropping my clocks incase it was an instability problem but the usage stayed the same.
and also as I said earlier pretty choppy!
I don't think anyone's asked but what drivers are you using?
What tool do you use to test GPU ussage?
I only get 50-60% on each on my cards but i am pretty sure it's my cpu bottlenenecking it as it should be a lot better with a 4770k soon.
If i get a chance Sycho, ill try my 670's in my other rig, (i7 930). If i can get it running at 4ghz, be interesting to see the card use in it and compare to the 3770k.I only get 50-60% on each on my cards but i am pretty sure it's my cpu bottlenenecking it as it should be a lot better with a 4770k soon.
Not using vsync at all, i get like 70-80fps most of the time on Caspian Border 64 player server with ultra and 4xmsaa at 1920x1080.
What settings are you running at? If you're running low settings the CPU bottleneck increases.
4.2ghz on my old 920, the only multi gpu setup i ran on it was a pair of gtx 470's. I do have a 930 based second system as well though.
Tbh im more worried if theres gonna be a guinness famine.Sounds like you've been stock piling those i7's incase of another potato famine.![]()
One i7 for a keg o stout and a tank of gas.Will see if i can get them running in it over the next few days, driver wise im currently on 320.00. Ive checked fps in bf3 with the ab osd running. Seeing upto 150 fps with the settings at ultra with x4 msaa, 85 fov @1920x1200, 91% usage per card.I've used 314.22s now using 320.18s which hasn't caused any issues just poor sli scaling in some games.
Please do that Setter would help a lot.![]()
