Post up a video with full sized platesIt's kind of hard to give feedback on what is effectively you squatting down too far and standing up with next to no resistance.
Have you watched the videos in the OP?
My arms don't even bend back that far I don't think![]()
I can fap to that.
I'm sorry for requesting the pic Mr T... please don't hurt me![]()
Haha im going to mate.
Im following the SL 5x5 weights so this is why there only little. Rather get it right before I do more challenging weights. Will post a more weighty vid.
Joe.
It would be incredibly rare for me to start someone on less than 60kg for deads. If you want to stick to the progression, put something under the plates to bring them up to the right height.
Thanks Ice. Going to change this on my routine now. I was starting at 40kg
I saw this for taller people too. Would you recommend I separate my legs like this dude? Clicky
That video is terrible!Thanks Ice. Going to change this on my routine now. I was starting at 40kg
Double underhand grip? Niiiiiiiiiiiiiiiice.
How tall are you?
Worlds longest legs! Long way to pull that bar.
6ft6 mate. Should I change to 1 under, 1 over?
Yes, being tall can suck for weightlifting purposes (I'm not going to pretend it doesn't), but if you want to do it badly enough, you have to suck it up. You could switch to mixed grip, but you have a technique problem that won't get any easier just by switching your grip.
Sort your technical issues out, and then see how you feel.
I think you misread my reply in what I meant. I thought your previous post with the Niiiiice as sarcasm (being the section of the forums it is, its kind of expected here). Im not bitching mate at all.![]()
 ), so...Whats the deal with deadlifting non olympic weights? with them being lower
