Yes this is a huge breakthrough, love my bios. I run 1093/1563 at 1.163v.
thats pretty high voltage mate for 1093 clocks, i would expect you to get 1140-1150+ with those voltages, as i can get 1163core clocks @ 1170v
Kaboom just finished baking me my official his bios
24/7 default clocks :
1070/1400 @1080v *very low voltage*
50% powertune unlocked
Boost Disabled
Whats great about this is the vcore voltage 1080v @1070
also all my ports work on my cards now incl hdmi 1.4 spec
and also msi afterburner works i tested it by changing the voltage to 1150v and it worked![]()
anychance you can upload your bios for me to try out, please![]()
. Increasing even 50mhz on this cards freezes whole system, so sitting at 1ghz..hey, iv got the gigabyte windforce 7950 with asic quality of 63.4, voltage locked @ 1.25V. Can i use this? I have the 2 switches on the gpu, so if the update failes i can just switch the switch and everything is ok?
Temps are maxing out atm at 70-75C so its not that hot, but i dont know, i just wanna play a little. Increasing even 50mhz on this cards freezes whole system, so sitting at 1ghz..
asics 79.3 just cant seem to get the temps down. thats just running gpuz render test
Bit of a pain as I have 1 card with 82.3 ASIC and another with 69.3 lol
I guess I should use one that's best for the lower quality so slightly higher volts.
Which one would be a good one for that as a starting point chaps?
Yeah so I think I probably have to aim for one to work with the lower ASIC (my newer card). I'm thinking the bios Ltmatt is using will prob be the best to try first?
