- 25 Nov 2011
- The KOP
I suspect the audio drivers are somehow messing with your mic in windows. Try doing a driver sweep as per the AMD thread. Reinstall the drivers but choose custom install and untick the HDMI drivers so they don't install. Use 13.6 beta 2 with cap 13.5.
Make sure you're using Beta 10 of afterburner. Disable ULPS is under settings, copy these settings.
You need to restart the pc after ticking disable ULPS.
Are either of your cards boost cards with a stock voltage of 1.25v?
I did driver sweep when switching to 13.4 and using 13.4 cap1
Just found beta AB lol ULPS is now disabled with system restart
My new card is 1.25 other is voltage free. Will that be a reason to anything?
I have matched my older gpu to the new clocks 900/1375 going to try bf3 again now.
with an average of 20%.
