I love these AD08s!
They are pretty lol worthy when it comes to a road tyre.
I love these AD08s!
How are people finding the Federal 595RSR's? I plan on fitting them to my Turinis on the Clio, but not sure if I should maybe spend more on the R888's?
I imagine they will be not so good.
As for them changing them, I expect you have little chance as you let them fit whatever, rather than specifying a tyre and them ignoring your request. They will then be stuck with "used" tyres...
I'm looking at either Goodyear Eagle F1 Asy 2's, Conti Sport Contact 5's, or Michelin PS3's which I had fitted to my old e36 without any complaints. The F1's get the better review but as always, different cars work better with different tyres. What would you guys recommend?
[TW]Fox;24467518 said:Michelin changed the naming convention with the PS3 - it's no longer the Michelin UHP tyre, that is a place taken by the Pilot Super Sport. The PS3 is more mid-range.
I'm also looking at 4 tyres in the near future and the shortlist is CS5 or F1AS2. To be honest I've been really impressed with the AS2's I've currently got so unless the CS5 is a comparative bargain I'll probably go for them again.
It could be something as simple as if the cuts are deeper then the blocks move too much when new.
It could be that their analysis on fluid motion shows pushing fluids sideways isn't beneficial when the channels are shallow.
Good job the dont put those cuts all the way through. Would be like jelly !
