New case! :O
20 Aug 2007
Solihull
Hey guys,
Looking for a new and nice case for my build, I was planning to upgrade but don't have the budget at the moment, but I do want a new case.
I needs to be Full atx tower with great cable management, good quality standard build and preferably good dust management, I HATE DUST! :(
I'd also prefer a windowed one, always gone for black as my colour but would be happy to try other colours
Budget - hmmmm shouldn't go over £80 really, but I do like shinies and it's payday soon!
ATX - Good quality - Cable management - Black - Shinny - Dust management - Window
How about a Fractal Design Define R4. Comes with all above and is also a quiet case.
Any many will say cases are subjective, but here you'll find some good options.
NZXT Phantom Enthusiast. Slightly over the £80 if you look in the right place
Or perhaps the Aerocool X3 Xpredator?
A fair way over budget but the Silverstone RV02/RV03 may be up your street.
Great cooling performance, lots of cable management options and a big window. :)
To add to the confusion it is also a 90 degree rotated motherboard. Graphics cards point up. Its the twilight zone of pc building.
500R seems a bit small for all my hardware :( could do with a full ATX tower :)
What are you going to put in there ?
Iv'e just moved my stuff from a 800d to a 500r and its superb,very quiet and plenty of room.
Asus board.
i7 920
gigabyte windforce 3 670
3xhard drives
ax 850
Still loads of room left :)
Asus board.
i7 920
3xhard drives
ax 850
The blue rig in the spec (6970 is massiveeee! c: ) also I have about 6 x 3.5" sata's sitting in the front end of my current case, an antec dark fleet full atx
