Anyone sleep with a weapon?
even if you do have a "weapon" and you had to use it, chances are you would be in the same cell as the chap that you used it on.
I'm guessing thats illegal? :p
an "asp" is just the makers name for a telescopic baton which you can readily buy from the internet.
Edit, turns out its harder than i thought to buy one from the internet. now i have police at my door asking why i want to buy one :p
to those that do keep a weapon nearby. You realise that the law states that you may use REASONABLE force to defend YOURSELF or YOUR FAMILY, and that the use of a baseball bat or knife or ASP probably wouldn't be classed as reasonable.
Also @JaWalks you of course realise that if you are pulled over and the police find tha they WILL throw the book at you and if you use it to beat anybody off that is trying to carjack you are breaking the law right? hell you are breaking the law by simply carrying in the cabin of the car let alone by your seat
:p
i keep baseball bat behind my bedroom door, you never know what could happen... rather have some sort of weapon to hand if needed
A huge knife, also removed everything that can be used as one.
6 lads with guns. Bam all doors lock, lights out - smoke. PHONE signal jams. Looking like Tom Clancy I knife em all with heatseeker googles. Picked up gun and wasn't a normal shot.
I aim at the wall *bang*. Followed bny a dropping body, then another through floor boards.
Got banned for using hacks.
^^Do you feel the need to point out everything you disagree with? I certainly didn't have a hissy fit:confused:. I made a joke but it didn't come across the way, maybe I should use more smilies.
I do find Arek's posts pointless and lacking anything worthwhile so what I do about it my choice. I don't jump on everything people post because it doesn't fit my view or it lacks merit but if that is how you enjoy passing time go for it.
ty and yes plz
