[DOD]Asprilla;24537900 said:Carrying a spare tyre doesn't make road debris get sharper and nor can road debris use your spare tyre against you. Oh and you can't be prosecuted for changing your tyre in an overly aggressive fashion.
Having a weapon doesn't make you any more likely to be burgled and doesn't make it any less likely that they'll flee if disturbed. And you'll still be left stranded if you get a puncture and you don't have a spare.
Is one of these things where people completely fail to assess the risk correctly and mitigate disproportionately.
As was mentioned earlier by someone I think keeping your loved ones safe is perhaps the best course of action. You seem to be assuming having a weapon means going Rambo on an intruder and I guess this could be the inference, but it's not what I'd do or recommend. There were a few break-ins very close to where I live a while back, and when I hear a sound now I usually pick up something to hand and check it out. Funnily enough just a couple of nights back I heard what sounded like the recycling bin being clipped, but most likely it was some glass stacked up that had slipped, that time I didn't take anything when checking.
I suppose I have the choices of not investigating or going unarmed, but I don't really like the idea of either of those, I'm not sure that any intruder who wouldn't tackle someone unarmed would go "Oh look he has a baseball bat, I was going to flee but I think I'll try and take it off him to beat him up". More likely people get injured in this way when they go mental and find that they are out of their depth.
I don't care about the prospect of being prosecuted, that old line is popularized by the Daily Mail et al jumping on every case, not that they aren't right to for those involved, but it distorts the reality. Generally you would only need to worry if you prevent them from leaving and then employ the weapon or use it excessively.
One thing I've got from this though, I probably don't make enough noise when I go to check things out. Still I'd rather not ignore things altogether and I'd rather not go unarmed.
What would you consider the best course? Do you think picking up something invites being attacked by an intruder?
