I think ive finally finished setting up my microserver, its taken about 2 weeks to get to a point where I can sit back and not have to tinker with it
So far ive updated the BIOS to the hacked version, installed the 250gb harddrive into the 5.25 bay, put 2x4gb generic ram in and replaced both fans.
I replaced the main fan with a Antec TrueQuiet 120 I had knocking about which is giving good enough airflow and is quieter than the original one.
The PSU fan I replaced with a Noctua 40mm fan, the header in the PSU wouldn't power the Noctua up so I ended up connecting the fan directly to one of the molex connectors.
The Nocuta is running at full speed 12v so isn't as quiet as I would have hoped but is still quite a bit quieter than the original 40mm fan and has a much nicer noise signature.
Im running Windows 8, I tried other options but it was easy to set up and I had a spare key, Im also using drive bender as a storage pool for the 2x2gb drives Ive got installed at the moment.
Ive also got it to boot directly into XBMC shell using XBMC launcher, set to power on via my tablet using PC Auto waker, Yatse for XBMC remote, akRDC for PC remote desktop (if I should need it) and uTorrent remote for well UTorrent
The Idea was to replace my Synology NAS but its more to compliment it at the moment but we will see
Ohh I forgot Ive also added a HD5450 as its connected to my home cinema system via a 7M HDMI cable allowing me to have the server in another room.
