Gigabyte HD 7950
22 Jun 2013
So I got my newly built PC today; installed the Graphics Card, all going well. What's the latest driver for it from their website? Or shall I just install the drivers that are on the disk that come with it?
Cheers, I think I've got the right one?
Desktop graphics
HD Series
Radeon HD 7xxx Series PCIe
Windows 8 - 64 bit
Then downloaded the catalyst software suite and the 'latest beta driver'
Is that right? Cheers
I also normally download the latest AMD catalyst profiles and install those, I've read they make a performance difference even if not running cross-fire. You should be fine without that though.
Cheers for that. After I've installed it is that all I do? nothing else? like I don't need to go in to the program or anything do I? cheers.
You may want to go into the Catalyst Control Center (it'll be an icon in the taskbar) and click Gaming, 3D Application Settings then change "texture filtering quality" to "High Quality".
