- 22 Sep 2008
- Burscough
I have a ceiling rose in the third bedroom that is a "loop in" wiring configuration (i.e. a wire going to the switch and coming back, and two L-N-E cables).
I have bought a light fixture for it, but this requires getting rid of/moving the ceiling rose into the loft space above and replacing it with a junction box like this:
http://www.diy.com/nav/fix/electric...-3-Terminal-Junction-Box-Brown-30-Amp-9289783
Which is essentially a sealed ceiling rose junction box. I then plan on running a short L-N-E cable to the light from the box (the light fixture itself will only accommodate one L-N-E connection, hence having to relocate the rose).
My question is, I see myself as being perfectly capable of doing this, but are there are requirements that mean I have to get a qualified electrician to do this?
