- 20 Jul 2009
- Midlands
Musing the idea of a FN2. It's an 08 plate with 10k on the clock.
What sort of things do you need to look out for on these and was there anything changed on the later models?
2010 onward saw LSD as standard, depending on where in the 07 your car is will mean facelift or no facelift. Essentially all they got was headlight washers which have 2 raised faces on the bumper as a result.
10k miles??? So long as their isnt rust along the front of the roof by the screen and you can change easily from 2nd to 3rd then theres not all to much you need to look as to be honest.
