When people refer to engine braking, do they mean sequential shifting to brake or the brakes and just the gear that they happen to be in at the time?
The compression of the pistons acts as an effective air brake on the road wheels when traveling at speed with the throttle plate(s) closed ie you slow a bit quicker than freewheeling it is an effect you can use in sync with normal disc braking; or alternatively you can use the hill scenario where you select first role off and will eventually find your acceleration restricted because you have reached maximum engine revolution in that gear.
