Please resize!
Looks like a nice setup but was/will never be a fan of external rads![]()
TPU Forums automatically resize photos for me![]()
eAny more Corsair 200R builds here? They look like a super case for £50, and since I'm interested in getting one would be nice to see a few more of you post pics of any others!![]()
e
Did you see mine a few posts up.
They are a super case really, well worth £50 and possibly a bit more![]()
.Nice and clean mate.
Just that 4pin fan connector dangling on the right that needs sorting.
Mik3 - I can't work out how your fans/rad work?
If they are pulling/sucking air out of the top of the case, then it's not cooling the fluid in the radiator, so serves as no benefit as the coolant isn't being cooled.
If they are blowing down then you're blowing hot air into your case?
Or have I missed something? (Probably!)
i would imagine the fans are pulling air out of the top of the case, i'm not sure how you think cooling a radiator works so i'll just say this; radiators can be cooled in push (blowing air into the rad) or pull (sucking air out of the rad) or push and pull together.
basically as long as there is air moving over the fins of the radiator it will be cooled.
Case is a Switch 810.
