Been busy putting the final touches to my new case,ordered a few enermax cluster 120mm,and 140 mm fans to add to it(with free haribo
),bought some uv spiral tubing to add to the h100i,and a couple of uv leds,tbh i'm a little underwhelmed with the uv effect,but its noticeable.
The case itself is overall,an improvement on the antec 1200,which although had good airflow and was fairly roomy,it felt smaller inside than the stryker,also the cable management with the striker is way better(although your not getting to see mine as it looks like black snake mating season
So overall i'm well glad i upgraded from the antec,i think i've now got the bug and am starting to chop up her Zalman z9 and see what i can do with it
so far i've taken out the drive bays at the bottom,cleared up the front a bit(cos the airflow wasn't the best) and fitted a coolermaster 200 mm fan
that should improve things a bit,dont have much for inside it though,just gonna use an old amd 2800 i had lying about and use it for playing blurays etc,and maybe burning.
Will post some pics if anyone's interested once it's done
